boosting my dohc
Old Oct 28, 2012 | 10:01 AM
blk99neon's Avatar
blk99neon
Default boosting my dohc
i have a 99 sport dohc that i want to boost! i want to get the perfect setup to get the best output i can. i dont want to do anything extra i just want boost. internals and stuff like that. i would like to put 10 to 15 lbs of boost on it! and what a good turbo!
Old Oct 28, 2012 | 02:43 PM
I_Ride_Neon's Avatar
I_Ride_Neon
So you plan to do internals or not? If not I would not run more then 10psi. Srt-4 turbo/fold, walboro 255, front mount intercooler, missing link, wideband/boost gauge, spool boy mod with RRFPR. That is after you go over the motor and make sure everything is healthy and no issues. Here is a little project log I did a few years ago on a dohc. It ran 5psi and pulled like a SOB. http://www.cardomain.com/ride/3307709/1996-dodge-neon
Old Oct 29, 2012 | 09:08 AM
blk99neon's Avatar
blk99neon
just stock internals. so 8psi would be alright? whats a spoolboy mod with RRFPR?
Old Oct 29, 2012 | 06:51 PM
I_Ride_Neon
Spool boy mod is the modification of adding a RRFPR, return line, and bypassing the stock regulator. RRFPR is rising rate fuel pressure regulator. I like the chill factory, Begi makes a similar one. You will also need bigger injectors like some srt-4 injectors. You can use the stock injectors, but the fuel pressure required is damn high.
Old Nov 1, 2012 | 07:36 PM
blk99neon's Avatar
blk99neon
Awesome! think u can send me a link to a website to buy the chill factory spoolboy mod?
Old Nov 2, 2012 | 10:23 PM
I_Ride_Neon
