New Piston recomendations
Old Jan 11, 2013 | 04:08 PM
Kyle Richard's Avatar
Kyle Richard
Default New Piston recomendations
Deciding to put new pistons in my DOHC neon and cant decide if i want to go 10.5:1 comp or if 11:1 is possible.
Also what is the best piston ring to go with if your on a budget?
Or would it be better and cheaper to put in a good set of cams and gears?
need some input thanks!
Old Jan 12, 2013 | 02:21 AM
Trialmaster's Avatar
Trialmaster
Just a cr buildt dont make it a dragster.
But if you want higher cr for less $, mill the head.
Then some good crower cams from Modern along with)
Is it a mtx?
Old Jan 12, 2013 | 05:56 PM
ohioguru's Avatar
ohioguru
or do a srt turbo on it. make easy power that way
Old Jan 14, 2013 | 06:23 PM
Kyle Richard
Is it a mtx?
What do you mean by: is it an MTX?
Old Jan 14, 2013 | 06:29 PM
Kyle Richard
Okay so i decided no to do pistons and go with cams. I know everyone recomends crane cams so i want to know what grind i should go with, they have like 12 through 18 or something like that. Also what do you guys think of compcams for the neon or crower?
Old Jan 15, 2013 | 02:22 PM
Trialmaster
Crane do not have cams for dohc.
Crower has.
Aviable at www.modernperformance.com
Do not over dimention your cam choise, cause of your stock cr. Big cams like higher cr.
Mtx is manual gear box.
