95 Neon injectors
Old Mar 12, 2013 | 11:00 PM
4doorneon's Avatar
4doorneon
Default 95 Neon injectors
I know the rules and I am suppose to do a search but this is a limited time chance and I am hoping the answer comes quick. I do not have my 95 SOHC anymore but the friend that bought it has been doing it a little more justice than I did. I seen a guy post injectors from the 95 RT, which is DOHC of course. I know they are the same but yet the 95/96 were the only years that had different injector plugs and coil packs. I was wondering if these were the same type plug?
Old Mar 13, 2013 | 09:33 AM
I_Ride_Neon's Avatar
I_Ride_Neon
95-96 have a different style plug then 97-99. You can put a 97 injector in a 95 if you have the pigtail. If you have a 95 and use a 96 injector, it will plug right in.
Old Mar 13, 2013 | 04:27 PM
4doorneon's Avatar
4doorneon
Am I correct in assuming the RT's are higher pressure?
Old Mar 13, 2013 | 06:07 PM
I_Ride_Neon
Nope they all flow the same. Sohc, dohc, r/t, 95-99 all flow the same. Only way to bump up the fuel is a 58psi regulator or aftermarket injectors.
Old Mar 13, 2013 | 07:01 PM
4doorneon's Avatar
4doorneon
Ok so buying these used ones would just be a waste of time than. I was hoping they might give a little better fuel/air ratio
