98 dodge neon
Old Jun 1, 2013 | 01:12 PM
cntrybndit's Avatar
cntrybndit
Default 98 dodge neon
I have a 98 dodge neon 5 speed sohc good starter and battery fuel pump is working car cut off after starting and running fine wont start back up i disconnected the fuel line at the fuel rail and it seems to be getting fuel please help
Old Jun 1, 2013 | 04:00 PM
Welcome to DF! Moving this to the Neon section.
Old Jun 6, 2013 | 03:55 PM
go-part's Avatar
go-part
Former Vendor
http://www.ifitjams.com/starting.htm
Old Jun 12, 2013 | 05:04 PM
Juggalotus01's Avatar
Juggalotus01
I had a similar problem with my 98 dohc and it turned out to be the ASD relay. i swapped mine with the horn relay and it started right up...might be worth trying. Its location atbleast on mine was under the hood inside a fusebox.
