98 neon sohc a/c help
Old Jun 8, 2013 | 03:05 PM
mudduc971's Avatar
mudduc971
Default 98 neon sohc a/c help
I have a 98 neon sohc trying to fix the ac i tested to see if the clutch was engaging it was when i hooked it up to a 12 volt source but dosent work when its plugged into the cars wiring harness i also checked the relay it was good as well im sure you guys have answered this bit im new to the ac game thanks.
Old Jun 24, 2013 | 12:22 PM
das2123's Avatar
das2123
I believe there is a fuse as well. If not, you might have to dig into the wiring harness.
