engine swap 95 dohc avenger in a 98 neon dohc??
Old Jun 21, 2013 | 04:37 AM
67fastback's Avatar
67fastback
Question engine swap 95 dohc avenger in a 98 neon dohc??
I have 98 neon dohc, the water pump seized and broke belt, and I am sure it bent the valves due to this is an interference engine... engine only has 88k on it....
Well looking for a quick fix, repair shop said 1k to fix.. car not really worth that.
So back to quick fix..
I found another engine but was not sure if it would work.
95 avenger engine dohc 2.0l .will this fit and bolt right up and how about the wiring harness? will I need to do anything with that? Not sure what issues I get into with the swap... I know the heads will not work due to porting and exhaust it reversed..
Any help would be grateful..
Other wise the car will be junked..
Old Jun 24, 2013 | 12:13 PM
das2123's Avatar
das2123
IIRC, the Avenger head is backwards from the neon head. Intake in the back and exhaust in the front. So a no go on the head swap unless you are ready to do some serious customizing.
If you are good with tools, just pull a DOHC head from a junkyard and throw it on along with a fresh HG and timing belt. Car will be good for another 100,000 miles.
