2.4 swap
Old Jul 12, 2013 | 02:40 PM
blk99neon's Avatar
blk99neon
Default 2.4 swap
I have a 99 2.0 dohc and I want to do a 2.4 swap. Can I use the motor out of a 96 dodge stratus and all wires hook up and mount up rite?
Old Jul 12, 2013 | 09:24 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Yea for the most part. You will use the sensors off your motor, your manifolds, and so on. You will need the motor mount adapter for the passenger side. Modernperformance sells them
Oh you will also need the 58 psi fuel regulator for a 2nd gen.
Old Jul 13, 2013 | 08:56 AM
blk99neon's Avatar
blk99neon
thank you! so when i do the swap i will keep the stock 2.4 injectors in and put the regulator in and everything will be good?
Old Jul 14, 2013 | 03:20 AM
I_Ride_Neon
Use your 2.0 injectors.
