1999 Plymouth/Dodge Highline Coupe 2.0 SOHC
Old Aug 6, 2013 | 04:14 PM
JRTRUCKINGANDREW's Avatar
JRTRUCKINGANDREW
Default 1999 Plymouth/Dodge Highline Coupe 2.0 SOHC
Can someone please get me a front brake diagram.
I cant get my brakes on the same way i seen them when i took them off.
Help please!!!!
Old Aug 22, 2013 | 12:18 AM
sbhawaiian's Avatar
sbhawaiian
I have a 2000 neon, is yours disc brakes also? If so it's usually pretty easy. 1st match up the old pads and make sure they are the same as the old ones. The 2 bolts holding the caliper comes out and the pads can be removed. use a "C" clamp and press the caliper piston back in until flush. You cannot reinstall caliper with new pads with doing this first. Go to youtube to see how it's done. Good luck
