99 dodge neon sounds weak when cranking
Old Sep 13, 2013 | 03:15 PM
leihero8118's Avatar
leihero8118
Default 99 dodge neon sounds weak when cranking
Hi, I have a 99 dodge neon with SOHC engine. Recently, my car sounds weak when cranking. My battery is about 4.5 years old. It is a 610 CCA battery. and I had the battery tested and shown 534 CCA left. The battery voltage was 12.54V. Time for cranking is 1.2 s. The meter indicated that the battery need to be replaced soon though I think 534 CCA is considerable amount left. Some new battery is only 550 CCA. so I think 534 CCA should be fine with my car. not sure the meter made the decision basing on the life of the battery or the status of battery.
I replaced a secondary starter in 2009. At that time, my car didn't crank.
For the situation now, my car cranked weakly when first I started it on the first ignition place. I turned the key more to the end, the car crank stronger and vibrated.
can anyone suggest it is more likely to be a battery problem or starter problem? thanks a lot
Old Sep 15, 2013 | 07:53 PM
blk99neon's Avatar
blk99neon
Sounds like the starter again...
Old Oct 7, 2013 | 01:52 AM
frankarnone70's Avatar
frankarnone70
Bad connection to battery or battery is no good.
