codes 23, 25
Old Oct 11, 2005 | 04:17 PM
jtvzero's Avatar
jtvzero
Default codes 23, 25
the engine light on my 96 went on the other day. it's been driving fine since but light is still on.
checked the codes and 23 and 25 showed.
any suggestions on what i should check first?
Old Oct 11, 2005 | 08:59 PM
casper's Avatar
casper
Default RE: codes 23, 25
23- Intake air temp sensor out of range.
25- Idle air control motor circuits, target idle not reached (+/- 200),vacuum leak found.
I would check for loose wires and if that does not work check the IAT and IAC, I believe they are all one sensor.
Old Oct 12, 2005 | 03:27 AM
RadarLove's Avatar
RadarLove
IAT is located on the intake manifold and is combined with the MAP sensor. Either the sensor is bad, the return wire is grounding out, or the input voltage (5v) is shorting out.
The IAC is located on the TB. Also has a 5v power running to it. Could be the IAC itself being faulty, the IAC being dirty and sticking, or power/ground shorting out.
Since there's a commonality there (5v), that's where I'd start. Follow those wires back to where they splice in and see if anything is out of the ordinary - broken, bare wire, pulled tight, overheating... Can sometimes be a pain to track down. Took me a while to figure out my TPS wiring was rubbing up against the edge of the valve cover and shorting out...
Best of luck!
