redline
Old Mar 2, 2014 | 02:44 PM
1995neonsohc's Avatar
1995neonsohc
Default redline
ok so lastnight march second I was driving and I felt the car pulling by it self and I pushed the clutch in and the rpm smammed to redline then stopped and went back to normal I changed the tps and map 3 days ago it was pretty strang I checked the throtal cable and opend the thortal up it does stick sometimes I cleaned it prior. I bypassed my heater core and the way i placed it there no stress on the throtal cable . it does seem to be loose I don see whre to tighten it tho
and been reading around and it sayed its my cruse control cable and my cruise control don't work for some reason befor I even got the car
hmm and it was on a old school bmw post but cant be much different right
Old Mar 7, 2014 | 01:39 PM
I_Ride_Neon's Avatar
I_Ride_Neon
IAC could be bad. Also sometimes the battery tray will crack and lay down towards the throttle body. When that happens it can hold the throttle open. Also check things like throttle body carbon build up, and check the cable to make sure it moves freely.
