rev limiter
Old Apr 26, 2014 | 11:05 PM
hondavtx2006's Avatar
hondavtx2006
Default rev limiter
have a 99 neon highline use as a race car. its a 5 speed and I have 195 tires on it. hit the rev limiter in 2nd really bad and no power in 3rd. what can I do. first race is in a week. test n tune was today and didn't go well at all.
Old Apr 27, 2014 | 12:34 AM
djbucky3's Avatar
djbucky3
Do you need to raise the rev limiter?
Old Apr 27, 2014 | 02:31 AM
hondavtx2006
Default rev limiter
im not sure I might have to
Old Apr 27, 2014 | 12:44 PM
djbucky3's Avatar
djbucky3
I am not sure about tuners for your car, but you might be able to find one that will raise the rev limiter.. I know for my 98 ram 1500, superchips allows me to raise the rev limiter.
Old Jun 1, 2014 | 09:09 AM
Ghost Neon 2's Avatar
Ghost Neon 2
What condition is this neon in? Mileage? When was the last tune up? What modification have been done to this neon to make it a more effective "race car?"
The rev limiter is in place to prevent the operator from damaging the engine. If your engine is stock, you really should not be revving the engine past 6000k-6500k for a sohc and 7200 for a dohc. There is no power past those respective shift points, just noise and engine stress. Instead make sure the engine is in the condition to endure the stress of racing. Proper fluid levels and quality engine and transaxle fluid, tires inflated to the correct psi, no codes or check engine light, and then look to improve on suspension and brake system.
