2004 neon brake issues
Old Oct 30, 2014 | 02:12 AM
roberthd69's Avatar
roberthd69
Cool 2004 neon brake issues
i have a 2004 dodge neon when i put in reverse it feels like e-brake in on but in drive its fine. please help!!
thanks
also i noticed that after driving for about 45 min it all works fine and no longer feels like Parking brake is on.
please help!!!!!!!
Old Nov 13, 2014 | 01:08 AM
sbhawaiian's Avatar
sbhawaiian
I would first pull the drum and do an inspection of the shoes. If the drums are hard to come off the brakes may be tight. I would also clean the whole area inside the drum, check the wheel cylinders for leaks, and put some anti seize on the 3 contact parts of each shoe. You can lastly adjust the shoes by removing the rubber plug and turn the adjuster for a close fit.
Old Dec 2, 2014 | 11:35 AM
roberthd69's Avatar
roberthd69
Default dodge neon brake issues
please help
Old Dec 10, 2014 | 01:01 AM
sbhawaiian's Avatar
sbhawaiian
Hmm During that first 45 min. do you smell brake lining cooking or is the drum hot to the touch? If not than I would think that it is not too tight. Also, does the hand brake apply with a reasonable amount of pull on the e brake? I just feel that there is no substitute for pulling the drum off and giving it a good inspection, cleaning, lubricating, and checking the wheel cylinders for leaks.
Old Dec 10, 2014 | 07:51 AM
please help
Have you done the inspection recommended above? You need to inspect your brakes. If you don't know how, I recommend taking it to a brake shop.
Old Dec 16, 2014 | 07:21 PM
roberthd69's Avatar
roberthd69
Thanks for the reply, i will have to clean, lubricate, and check the wheel cylinders for leaks.
I will post if it works thanks again!!!
