Alternator is overcharging
Old Aug 19, 2015 | 10:41 AM
Jason Hartwick's Avatar
Jason Hartwick
Default Alternator is overcharging
My alternator on my 1998 dodge neon works at 13.57 volts at idle but when I hit 3000+ rpm it spikes to 32 volts my radio shuts off my amplifier shuts off and it threw 5 obd II codes p0149 p0403 p0123 p0113 and p1492 I did the big 3 I have a high output alternator I resistant checked all my grounds is the pcm malfunctioning or did the overcharge fry all those sensors
Old Aug 19, 2015 | 10:19 PM
ClaytonH's Avatar
ClaytonH
Voltage regulator is built into the alternator on most cars. Is the alternator stock? Pull it out and take it to autoparts store and have it checked for free. Autozone and Advanced are typically across the street from each other. Take it to both and tell them the problem and see if they can get similar results.
Old Aug 20, 2015 | 09:45 AM
Jason Hartwick
It's aftermarket and the voltage regulator is built into the pcm
Old Aug 20, 2015 | 07:43 PM
ClaytonH's Avatar
ClaytonH
The solution points to itself. If not the alternator it may be the PCM or the wire harness. Much less work to have an alternator checked. I'd start there.
Goodness knows what you have added to the wire harness with the amps and such. When I bought my Neon the kid who owned it before me installed an amp... it melted the wire harness. He pulled the insulation off parts of the harness which let it rub and cook on parts on the engine too.
http://forums.neons.org/viewtopic.php?f=1&p=3007353
Old Aug 20, 2015 | 11:14 PM
Jason Hartwick
Already redid like half of the wiring harness for the engine from like the coil pack down cuz the oil pressure sensor already melted all those wires
Old Aug 21, 2015 | 08:28 PM
ClaytonH's Avatar
ClaytonH
FFS man... use your head. Have the alternator tested. It's that or the PCM or the wiring/grounding. It's not a stock alternator, maybe your PCM can't manage it.
My definition of stock is not OEM but what the part store tells me is compatible. It may not be an OEM alternator but it is designed to work with the charging system of the car.
In the linkl provided NickKo said it "I think that only a very small group of people have managed to sucessfully convert over to an external regulator.
I think those are all Megasquirt users, who's engines are not dependent upon the PCM, for management.
That would require a lot of work, so it goes beyond the scope of this discussion."
I love autoparts stores. Can get lifetime warranties on so many parts. Sad thing is I have had to return parts within a couple of months because they fail. Re-manufactured or whatever reason. For gods sake man. Have the part tested if there is an issue. Its free... and they'll happily swap the part.
That is unless you didn't know what you were doing and just ordered the largest alternator you could find that would fit the car...
You like the moron who owned my car could only think about how to rice out the car. Why bother consider what was compatible with the existing hardware. Ignorance is bliss until crap starts going wrong.
You're answering your own questions. PCM controls the charge/voltage rates. Alternator is putting out too much voltage. DUH!!! The answer points to itself.... Alternator, wiring or PCM.
Old Oct 11, 2015 | 05:42 PM
ClaytonH's Avatar
ClaytonH
So, what happened with that?
