Reverse lights on
Old Oct 2, 2017 | 02:05 PM
CraigREitner's Avatar
CraigREitner
Default Reverse lights on
I purchased a used 95 neon 2.0 sohc 5-speed and the reverse lights are stuck on even though they are not plugged in to the switch on top of the transmission under the battery box. I searched for wires that could be the problem but nothing came of it. And it also has a plug as if it would be hooked up to be towed behind an rv or something. I will add pictures when I can.
