remote starter
Old Dec 5, 2005 | 09:52 PM
95SPRTcpe's Avatar
95SPRTcpe
Default remote starter
alright, so i found out that you CAN put a remote starter on a MTX car. so is there a special kind of remote starter i'd need to buy? or can i just use the one i already have even though it says for ATX cars and just leave it in neutral with the e-brake up? any info would help
Old Dec 6, 2005 | 08:37 AM
RadarLove's Avatar
RadarLove
Default RE: remote starter
I jumpered out the clutch switch for mine, works great. You just have to ALWAYS remember to leave it in neutral. Starter yells at you if you forget...
Best of luck!
Old Dec 6, 2005 | 03:35 PM
95SPRTcpe's Avatar
95SPRTcpe
how do i jumper out the clutch switch? and where is it?
Old Dec 6, 2005 | 04:15 PM
RadarLove's Avatar
RadarLove
There's a little push switch on the top end of the clutch pedal. Remove the connector going into it. Cut. Splice. Hardest part is getting the stupid connector off.
Old Dec 6, 2005 | 04:31 PM
95SPRTcpe's Avatar
95SPRTcpe
alright, thanks for the help
Old Dec 8, 2005 | 02:55 AM
bossmankx's Avatar
bossmankx
A little off topic, but how hard is it to put one of these little buggers on an ATX car? and which one would you guys suggest?
