96 SOHC 2.0 Crank Shaft sensor
Where is the cranksharft sensor located? Will this cause my car to stall after about 20 mins of running? I have to let it set for about 20 mins after it dies before it will restart. Thanks
Here is link to where it is on a 95 2.0, I would imagine it is in the same place: http://www.techknowman.com/Dodge%20Neon/sensor_1.jpg
I had a crankshaft position sensor go in my old cavalier and it would stall when the engine warmed up, then I would have to let it sit for a while to get it running, then it did it over again.
Hope that helps.
Hope that helps.
