Thud from stop to fast acceleration
Old May 22, 2023 | 05:51 PM
HobbyFarmer's Avatar
HobbyFarmer
Default Thud from stop to fast acceleration
I just got a ‘98 Neon H, automatic, SOHC 134k miles. I’s been sitting idle for a year. I changed the valve cover gasket, vacuum lines, oil, filter, and spark plugs. I also re-soldered the instrument cluster due to speedo issues. I am getting a thud from the front end when accelerating quickly from stop. It doesn’t happen with slow acceleration. Any ideas?
Old May 22, 2023 | 06:22 PM
ol' grouch's Avatar
ol' grouch
Unless you're hitting something, it sounds like your engine mounts. There are to on the passenger side and a transmission mount on the drivers side. The upper comes apart and part of it is a bear to get to. The lower is easy to replace. The transmission mount is not easy, but not too bad.
Old May 22, 2023 | 06:33 PM
HobbyFarmer
Thanks, I’ll look
