polyurathane motor mounts
Old Feb 7, 2006 | 05:06 PM
lavallainc's Avatar
lavallainc
Default polyurathane motor mounts
i just bought some. my friend got them for his sunfire and he said what a difference they make i was wonder if any one got them for a neon and if they felt any difference. and i was thinking about buying srt 4 rims i know the lug patteren is the same but will they fit on the car. thanks
Old Feb 7, 2006 | 06:51 PM
casper's Avatar
casper
Default RE: polyurathane motor mounts
The motor mounts are a good idea. You will feel a little more vibration but not bad. Do you have 4 or 5 lugs? The pattern for the 1st gen is either 4X100 or 5X100
Old Feb 8, 2006 | 11:23 PM
lavallainc's Avatar
lavallainc
i have 5 lug i jsut wanted to know if they will clear cause i was gunna order them off ebay.
Old Feb 15, 2006 | 07:48 AM
RadarLove's Avatar
RadarLove
The wheels will clear without any problems. Stock SRT-4 tires won't. The regular SRT-4 wheels are 17x6" with a 45mm offset (closer to the hub) and 205/50/17's, which will very likely rub on the bottom of the spring perch in the rear, assuming you have stock struts and not true coilovers. The SRT-4 ACR wheels are 15x7" with a 40mm offset (same as regular Neons) and 225/45/16's, which I guarantee will rub on the rear training arms.
Best of luck!
