1998 Dodge Neon questions
Hello everyone! I am a newbie who is looking for some of your help and opinions. My brother has a 1998 Dodge Neon with 91k on the motor. Anyways the motor makes a slight knocking sound but he said that is has been making that sound since he got it. My questions to you is, is that normal for a neon? I have read that other are having the similar sound but i just want to make sure. I have taken it to a local shop and they said they can't figure it out where the sound is coming from without taking the motor apart. Any info would help.
Thanks Josh
Thanks Josh
As has been aswered a thousand time, neons are know for a cold idle tick. I can't hear what it sounds like in your typing, but if it sounds mild your probally fine. If the motor sounds like its gonna blow itself apart its a problem. If you had a trusted mechanic look at it then I would go with them as they are suposed to be professionals and did listen to the sound.
