02 sensor removal
Old Feb 24, 2006 | 10:08 AM
spudsterier's Avatar
spudsterier
Default 02 sensor removal
i was wondering if anyone knew of a way to remover the downstreat o2 sensor without setting the check engine light?
other then buying an aftermarket computer
Old Feb 26, 2006 | 02:34 PM
RadarLove's Avatar
RadarLove
Default RE: 02 sensor removal
On the '95, and the '95 only, you can remove it with the Mopar PCM.
On the '96-up, you can use an O2 simulator. Casper's Electronics and Howell Automotive sell them. They work 99% of the time, but the CEL will pop up every now and then. Also keep in mind that the d/s sensor on the '96-up Neons does go into the fuel trim calculation. You probably won't notice it much on a mostly stock car though.
Best of luck!
Old Mar 2, 2006 | 07:49 PM
dazzellers_95's Avatar
dazzellers_95
so, if you have a mopar ecu, for the 95, and have the d/s o2 unplugged, it will quite throwing a code? now, if i can just get my parts i will be set.[:@]
