oil leak and gas leak when fueling
Hi I have had an oil leak in my car for awhile now it's not really bad but I replaced the oil pan gasket thinking that was it but it wasn't my anti- freeze is kinda milky looking. Now when I fuel my car the gas leaks out somewhere when it's over fueled the pump usually shuts off when it gets full. Now when it over fills it leaks? I have no clue whats up can anyone help me???
Definitely sounds to me like you've got a blown head gasket. That would be the reason why your antifreeze is milky looking. I'm not very qualified in telling you how to go about getting this fixed, but my brother's blown two of them so I know the symptoms. It's expensive to fix, that's for sure. Good luck with that.
ORIGINAL: rifsm1
i got under it and checked the fuel line from the opening to the tank and its all cracked and looks rusty where do I get a new 1 if thats possible???
