APEXI s-afc II
Old Mar 8, 2006 | 08:29 PM
thefamilyguy209's Avatar
thefamilyguy209
Default APEXI s-afc II
Does anyone have any experiance with these. I am looking to add a WB o2 sensor to my turbo kit and want to know if the apexi will control my fuel management. I need the bare minimum piggy back unit to keep things as painless as possible.
Old Mar 9, 2006 | 07:36 PM
thefamilyguy209
Default RE: APEXI s-afc II
so if no one has tried this particular unit hows about the greddy e-management
Old Mar 13, 2006 | 06:13 PM
thefamilyguy209
OK so whats the best way to control the fuel delivery to a turbo'ed car
Old Mar 13, 2006 | 06:30 PM
highline95jl's Avatar
highline95jl
Greddy is crap, dont waste the money, your best fuel delivery system for a turboed car is the stock PCM or Megasquirt.
Old Mar 14, 2006 | 01:26 AM
RadarLove's Avatar
RadarLove
Most guys use a rising rate fuel pressure regulator setup. That includes the fuel return line, better pump, and bigger injectors on the stock PCM. More and more are going to a Megasquirt setup (except for 2003-up...).
The Apexi S-AFC adds fuel based on RPM. It doesn't care how much air is actually getting into the engine. Not a good choice for forced induction fuel control. I have seen a modification (Eclipse) where a guy used the signal from a boost pressure gauge to trick the S-AFC, or something along those lines... don't remember enough from it to do you any good though... Anywho... Megasquirt can do on-the-fly wideband a/f tuning. That's a big reason to go that route...
Best of luck!
Old Mar 20, 2006 | 01:15 PM
1320rt's Avatar
1320rt
cant go wrong with megasquirt and their system is not crazy expensive... they quoted me 525 complete... crazy huh
