Weird spark after timing adjustment
Old Mar 19, 2006 | 09:23 PM
coocoobird's Avatar
coocoobird
Default Weird spark after timing adjustment
Ok so I adjusted the cam gears and crank. The strokes sound alot stronger now. But now the spark is weird. Before i adjusted it sparked good.. now it sparks once then no more sparks. I tried another coil and the same thing. This thing is starting to fustrate me.. ahhhhhh.. what should i try next?
Old Mar 19, 2006 | 09:49 PM
unlead's Avatar
unlead
Default RE: Weird spark after timing adjustment
think about a new computer ?????? i've broke mine last month and it cost me a brand new one... dodge make it realy easy to work... for them of course... it's a resistance into the board that blown.... somethimes.. the car runs.. but stall after a few turns... try a junk yard one(if it's realy that.... the car just run great if not... you can be refound)
Old Mar 19, 2006 | 10:39 PM
highline95jl's Avatar
highline95jl
If you didnt disconnect your pcm youve probably made it retarded. You can take it to the dealer and have them reprogram it, or go buy a new one.
Old Mar 19, 2006 | 10:44 PM
coocoobird's Avatar
coocoobird
ORIGINAL: highline95jl
but doesnt that seem "retarded" to have to buy a new computer or have it reprogrammed everytime you service your car?
Old Mar 20, 2006 | 10:46 PM
unlead's Avatar
unlead
what did you meen by every services???? everytime you repair your car it brokes again and again??? man if it's that....just find another wiring harness, a 50$ easy make!!!if you starting to had problems with wires.... think about it... i prefer to change the whole harness. I don't care about electric problem(even if i'm already an electrician), a person better than me is paid to make this ! :P
Old Mar 21, 2006 | 11:07 PM
coocoobird's Avatar
coocoobird
Ok i got the timing right finally.. and now i have awesome spark and great fuel pressure.. Now the on to the next problem! Bring it on i say!
