Another bad find. Low compression
Old Mar 21, 2006 | 09:48 AM
coocoobird's Avatar
coocoobird
Default Another bad find. Low compression
I did a compression test the other day and found that i was getting 30psi in the 1 2 4 cyl and 60 in 3 cyl. Before i got this car the head was just rebuilt. Not really sure if the rings are bad or something they did wrong with the head because the car never has ran since the guy before me had the head rebuilt and other various problems fixed. What should i be checking first? Would the car even start with that low of a compression?
Old Mar 21, 2006 | 11:11 PM
coocoobird's Avatar
coocoobird
Default RE: Another bad find. Low compression
I got some weird findings after adding oil to each cylinder and retesting. After adding the oil, all of the readings went down. Also when testing cylinder 3 it blew out of cylinder 4. So im guessing its the head gasket. I will tear it off tomorrow and check the gasket, will also check the rings while im at it.
Old Mar 21, 2006 | 11:19 PM
FuzzRacer's Avatar
FuzzRacer
seeing how the head was just rebuilt I would highly doubt it would be from cracks but I think a better gasket would have been used. Try doing more compression tests and see how long it will hold pressure, it could be from when the head was rebuilt that it wasn't smoothed down enough and leting air get in, start at the test. then go to the gasket hopefull things will work out so you dont have to go that far, if your gona go that far minus well check it all out rings can cause a compression issue too hope you find the problem
Old Mar 21, 2006 | 11:23 PM
coocoobird's Avatar
coocoobird
ORIGINAL: FuzzRacer
It seems to hold the compression . But i will try some more tests on it tomorrow.. I think i will just go ahead though and rip the head off.
Old Mar 22, 2006 | 02:47 AM
FuzzRacer's Avatar
FuzzRacer
Go for it and good luck, hope you find the problem and remember to use a good headgasket the ones came equiped on the neon aren't as good as they should be mopar makes a new and improved gasket now
Old Mar 23, 2006 | 10:00 PM
coocoobird's Avatar
coocoobird
ORIGINAL: FuzzRacer
Spudsterier figured out the problem, the cam gears were on the 2.4 side instead of the 2.0 side. Just flipped the gear over.. and BOOM fixed the problem.. and the car fired up .. first try.. insane..
Old Mar 24, 2006 | 02:47 AM
FuzzRacer's Avatar
FuzzRacer
Thats good, congrads glad everything worked out
