code 11
Old Apr 4, 2006 | 04:34 PM
93 tona's Avatar
93 tona
Default code 11
i keep getting it after I drive like 15 20 minutes replaced coil pack and harness, still no luck
Old Apr 5, 2006 | 01:52 AM
RadarLove's Avatar
RadarLove
Default RE: code 11
Code 11 could be a faulty crank sensor or a timing belt that has skipped a tooth. Ignition timing and cam timing are not the same. If you can get to a place that will pull the 4-digit codes (like Autozone) for free, it'll help narrow things down a little.
Best of luck!
Old Apr 5, 2006 | 01:46 PM
93 tona's Avatar
93 tona
Default RE: code 11
they got 1390 i believe he said, I know he said it meant timing belt skipped a tooth, to I put it to tdc and swapped belts, still comes on, also check my other post about 0-60 in like 18 seconds
