umm quick question i put....motor oil in my transmission fluid goes... wat happens now?
you could just drain it out and then run a few more quarts or trans fluid through it..and then get some trans flush...it should work fine
i put a quart in there and i dorve it about 2 miles lol i had to get home and now its sittin out side mind tellin me when the bolt is to drain the fluid?
it looks like the drain plug for the oil...only its on the bottom of the tranny....it comes out the side though...should be maybe a 15mm
so drain it and just refill it basically but how much do i have to refill it wit 1 gallon? 3 quartz?
Change the filter...too....you might be better of doin the full flush cuz the tq converter might have a little in it too...
yeah that would be good, just drain it all out, get some tranny flush and follow the directions on the container...then put the filter on..last
If you have an ATX, you need to drain all the fluid out, change the filter, flush the trans. Run the car for a few miles, and do it all again. Then fill it again and you should be fine. The torque converter holds quite a bit of fluid, thats why you need to do it twice. If its a MTX, you can probally get away with only doing it once.
