Its all making sence
Old Apr 12, 2006 | 07:40 AM
HabitatHxC's Avatar
HabitatHxC
Default Its all making sence
This is all starting to make sence now, when i run my car for a long period or run it hard, it seems to lack fuel to the motor (or what i thought would be water in the gas) i turn the car off for a few, turn it back on and im on my way again. i told a friend the problem and he said fuel pump, filter, or even injectors.
Anyone think otherwise? Any sugjestions?
Old Apr 12, 2006 | 08:28 PM
93 tona's Avatar
93 tona
Default RE: Its all making sence
I had the same problem and wasted 400 bucks fixing it before i figured it out. I had gotten a hole in my fuel filler neck, and the back tire was kicking crap into my gas tank. IT was the fuel pump filter, I had found three hand fulls of crap in the tank. drop the tank, and check you could get luck and get away with just filtering the gas
Old Apr 14, 2006 | 06:08 PM
HabitatHxC's Avatar
HabitatHxC
im like 95% sure its the pump or the filter, it only starts to run like crap when it gets down below 3/4 full of gas
Old Apr 17, 2006 | 03:59 PM
93 tona's Avatar
93 tona
check the filler neck, and if not that trry the fuel pump. for like 30 buck you can get a fuel pressure check tool and check that way... also when it die take a wrag and screw driver and depress the schroeder(sp) valve on the center of the fuel rail. and the see if it starts up then. hope this helps, like I said $400 and then I figured it out.
Old Apr 18, 2006 | 05:01 AM
HabitatHxC's Avatar
HabitatHxC
my filler neck went bad a couple months ago and we fixed that, for the longest time when we had the fuel pressure gauge hooked up the gauge would flip out between a certain point, (when the car was running fine) and after we replaced the pump and filter the gauge stayed right at like 45 or something like that. i havent had a problem since then!!! *knocks on wood*
