head gasket problem!
Old Apr 25, 2006 | 01:41 PM
Niki_lauda's Avatar
Niki_lauda
Default head gasket problem!
i read many documents and i heared that all neons untill 98(November! after that it replaced with steel plate) has gasket problem! and i wonder that how long it holds on in a good engine run conditions?-(i dont mean overheating and so on..) owners must be know it mileage..
Old Apr 25, 2006 | 03:13 PM
highline95jl's Avatar
highline95jl
Default RE: head gasket problem!
Anywhere from 30 to 60 thousand miles before it goes.
Old Apr 25, 2006 | 03:20 PM
das2123's Avatar
das2123
100,000 miles on the MLS gasket, so I'd change it with the timing belt, water pump and tensioner pulley.
Old Apr 26, 2006 | 08:27 AM
RadarLove's Avatar
RadarLove
The MLS gasket holds up really well. I've know plenty to go over 100k. I'm at 240k, MLS since 65k...
Old Apr 26, 2006 | 11:38 AM
das2123's Avatar
das2123
ORIGINAL: RadarLove
True...afterall if it blows and you catch it quick enough, it's not like the timing belt going on you.
