Odometer
Old Apr 28, 2006 | 09:49 PM
neoncrazy101's Avatar
neoncrazy101
Default Odometer
I just got my speedometer working (after 45,000 miles) and i'm wondering if anyone knows how to change the odometer reading to the proper mileage? i know its illegal to change the mileage on the odometer and all but does anyone know how to change it?
Old Apr 28, 2006 | 10:46 PM
spudsterier's Avatar
spudsterier
Default RE: Odometer
if you take out the number wheels, you can put the end of a drill on the little nub that comes off the end...find sumthing to hold down the trigger on the drill and let it roll
Old Apr 28, 2006 | 11:02 PM
neoncrazy101
ok then how do u take out the number wheels. cause i've tried to take them out before but couldn't so how ya do it?
Old Apr 29, 2006 | 01:29 AM
spudsterier
when you take out the cluster, remove the torx screws that hold on the circuit board...then there should be a few screws that hold in the numbers...i believe that is it...just remember not to try and move the numbers by hand or try to pry them or you will brake them apart....and it will take a while with the drill but it will get it there
Old Apr 29, 2006 | 02:35 AM
neoncrazy101
ok thanks!
Old Apr 29, 2006 | 10:07 AM
spudsterier
oh yeah...and you are gonna have to pop the numbers outa the housing...there are kinda like retainer pin on each end(these are what you put the drill on...and make sure that you hold the numbers or they will skip and mess the whole thing up
