Code 14 MAP Sensor
Old May 8, 2006 | 05:49 PM
Zapp's Avatar
Zapp
Default Code 14 MAP Sensor
I have a 1995 Neon with about 82,000 miles. It has been hesitating and stumbling.
I checked the codes and got 12 and 14. I know 12 is nothing to worry about and 14 is MAP Sensor voltage low.
I am just not sure what to do about it. Do I just buy a new MAP sensor and put it in or is there something I should try first?
Any tips will be greatly appreciated. Thanks!
Old May 8, 2006 | 06:18 PM
casper's Avatar
casper
Default RE: Code 14 MAP Sensor
Replace the MAP sensor and go from there, they don't go that often, but they do go.
Old May 8, 2006 | 06:53 PM
das2123's Avatar
das2123
Try pulling out the sensor, cleaning it, and then make sure it is seated securely.
