can any one help with this code?
Old May 25, 2006 | 11:31 PM
redr/t's Avatar
redr/t
Default can any one help with this code?
ok i just fixed my car now the severice engine soon is on and it gave me this code PO441 the pcm has determined that the purge flow in the evaporative emission control system is incorect for the current engine operating conditions 1st qustion what is that mean 2nd is will it hurt my car to run it till thrusday with out it 3rd would that make it stutter and almost stall
Old May 26, 2006 | 09:22 PM
das2123's Avatar
das2123
Default RE: can any one help with this code?
Check hoses to make sure they are on tight, cut ends if necessary to eliminate stiff rubber. Remove and reconnect the electrical connections. Make sure your gas cap is on correctly.
Old May 26, 2006 | 11:16 PM
redr/t's Avatar
redr/t
thanks das2123
