tranny question
Old May 26, 2006 | 11:17 PM
burpleneon's Avatar
burpleneon
Default tranny question
will a transmission from a second gen work in a first?
Old May 27, 2006 | 03:18 AM
das2123's Avatar
das2123
Default RE: tranny question
ORIGINAL: burpleneon
For the MTX a 2000 will bolt on because it's a cable clutch like the first gen. 2001+ are hydraulic clutches so you would need to swap out the bellhousing.
If you are referring to an ATX then the 2001-2004 trannies are a 4 speed and won't work w/o major modding and then you will have to deal with the heat problem.
