will not fire
Old May 31, 2006 | 01:51 AM
Ramrat's Avatar
Ramrat
Default will not fire
ok was driveing down the road and she just died with no worning, when i opened the hood i saw the ground from the batt to the body was snaped off at the body, rehooked it and nothing, checked for spark, nothing. changed the coil pack, nothing. she'll turn over but will not fire, throwing no codes and up till the time of death was running like a raped ape. any thoughts? i'm thinking maybe jumped a tooth on the timing but be for i rip her apart, i wanted to see if you guys had any ideas
Old Jun 1, 2006 | 02:46 AM
Ramrat's Avatar
Ramrat
Default RE: will not fire
well if anyone is interested it was the 20 amp fule pump fuse was blown
Old Jun 1, 2006 | 03:14 AM
IGottaFreeNeon's Avatar
IGottaFreeNeon
My fuel pump fuse blew one time also, it ended up being a problem with my o2 sensor. It looked like the wires got burnt and just shorted out. Anyways, I think that the fuel pump is wired with a whole bunch of other stuff. Also, I've been reading about alot of peoples problems about their Neons not starting. Maybe take a look over those old messages and you might find something that you have in common with them. Sorry I couldn't help at all.
