whitch belt
I just had both mine changed today, the receipt says 47515 for one belt and 345K4 for the other, the job only cost 30 bucks to do. those are for the OEM specifications. if you have a Performance Underdrive pulley the size for the underdrive will be diff and the size for it should be included with it if not the belt itself the belt sizes I gave you where for the DOHC engine Im guessing you have the SOHC from what you have stated with your HP rating. http://www.partsamerica.com/ProductL...+Belts&ptset=A that link should be what you need with the SOHC and the DOHC is http://www.partsamerica.com/ProductL...+Belts&ptset=A
for some reason the website doesnt list the 4715 belt but its there at the store and cost $5.44 Good Luck
go to your local parts store. most of them now have computers that have tis type of info. tell'em what you got and what you need. if nothing else call a dealer and they can tell you the size you need if you can't read it on the belts that are on your car now.
