two questions??
Old Jun 5, 2006 | 08:04 PM
burpleneon's Avatar
burpleneon
Default two questions??
the first how hard is it to take off the crank pully and second wheres a good place to get some tires and rims?h
Old Jun 5, 2006 | 08:16 PM
das2123's Avatar
das2123
Default RE: two questions??
ORIGINAL: burpleneon
It's easy if you get the correct puller with the correct insert.
Alot of people like tirerack.com...I get mine from tires.com
Old Jun 5, 2006 | 10:50 PM
dogdaysunrise's Avatar
dogdaysunrise
i used a 4" gear puller with no issue
Old Jun 14, 2006 | 09:00 AM
sethsneon69's Avatar
sethsneon69
I've found that one of the best places for some nicely priced tire and rim packages is www.discountedwheelwarehouse.com
