I need help
Old Jun 8, 2006 | 03:42 AM
dogdaysunrise's Avatar
dogdaysunrise
Default I need help
Okay I have swapped over the motor and all the sensors from the old motor onto the new motor. I am not getting any spark. It gets gas and air. It cranks over also.
I am not sure what is causing the lack of spark. I have checked everything I can think of. Any suggestions would be very much appreciated. I am at a loss.
Thanks,
Mike
Old Jun 8, 2006 | 02:49 PM
das2123's Avatar
das2123
Default RE: I need help
You swapped in the whole DOHC motor.
Old Jun 8, 2006 | 05:58 PM
drummiesdodge's Avatar
drummiesdodge
I swaped a 97 dohc with a 95 dohc i chouldent get it to fire up. i checked the wires to the coil pack so i whould check that and if it dosent work u might have fried your coil pack
Old Jun 8, 2006 | 09:12 PM
dazzellers_95's Avatar
dazzellers_95
What about swapping the ecu?? did that happen??
Old Jun 8, 2006 | 11:14 PM
dogdaysunrise
well they were both sohc motors, and the pcms wont interchange. I put all the sensors off the 97 on the 95 motor so it should read fine.
it is a pcm from an ATX car and I put in a MTX. I made sure the neutrel saftey switch was engaged however.
Im at a loss....
Old Jun 17, 2006 | 11:44 PM
95SOHC's Avatar
95SOHC
ya...see the thing with the 1995 neon is that the sensors are a little different...on the 96 and later the..i think MAP sensor and Air intake temp. sensor are both combined in 1 but in the 95 they are seperate!!so u might want to double check the sensors..
Old Jun 18, 2006 | 05:49 AM
pimpberetta's Avatar
pimpberetta
A engine ground somewhere? Check your grounds maybe, wouldn't hurt.
Sean
