NEED HELP!!
Old Jun 13, 2006 | 09:08 PM
spyder0091's Avatar
spyder0091
Default NEED HELP!!
i got a 95 neon and it doesnt have a wiring harness in it for the radio, its just wires there, how do i know which is which? can i get a diagram of that?
Old Jun 13, 2006 | 10:13 PM
sethsneon69's Avatar
sethsneon69
Default RE: NEED HELP!!
all ya gotta do is get a tester and check all the cut wires to see which one has power to it, Twist your power wire on your cd deck to the power wire you found, then find a holes or somethings and get a little screw and wrap your ground wire around the screw and screw it into the hole, simple, my prob is that I cant figure out how to get the cd deck out my my 96 neon, Can ya help me with that (i dunno what to do to get the interior piece off)
--Edit--
After looking on www . neons . org i felt soooooooooooooooooooooo bad that I actually asked the question about the center bezel, Had the cd deck in my lap completely unhooked in under 30 secs lol (used a lil solder cause the power wire was jury rigged so I soldered it and now it works perfect, still able to use the harness too:P)
Old Jun 14, 2006 | 12:52 AM
spudsterier's Avatar
spudsterier
to get off the trim piece, fold down the ashtray,and grab the piece where it goes under there and grab under the cigar lighter, then just pull
Old Jun 14, 2006 | 01:51 AM
das2123's Avatar
das2123
ORIGINAL: sethsneon69
But how does that tell him which are speaker wires and where they lead to?
Old Jun 14, 2006 | 02:38 AM
spudsterier
trial and error is a pain in the azz
Old Jun 14, 2006 | 11:08 PM
sethsneon69
yea but the basic thing ya need is a power wire, you can easily trace the speaker wires from the speakers or if ya lazy you can just run seperate wires all together, but if you still need help then just pm me and ill jerk out my kenwood deck and tell ya whats what (wiring harness still has most of the lil labels on it)
