FOG LAMPS
Old Jun 16, 2006 | 06:27 PM
tjharder's Avatar
tjharder
Default FOG LAMPS
I am having no luck with my idiot parts guys.
I have 98 coupe SOHC. I want to install fogs lamps. I have the switch connector in the dash by the defrost control. I have the bumper and lamps. I have two empty connectors on harness in front of radiator but they are not long enough to reach lamps. I know there has to be a harness but cannot locate part number. Are the two connectors in front of radiator not for fogs??? I looked at co-workers 98 4-door with factory fogs and his harness looks completely different.
Old Jun 16, 2006 | 09:15 PM
pimpberetta's Avatar
pimpberetta
Default RE: FOG LAMPS
If they are on the timing belt side of the engine, then its possible they were for the a/c compressor at a point in time.
Sean
Old Jun 17, 2006 | 02:44 PM
tjharder's Avatar
tjharder
the connectors are in the middle and front of the radiator. They are no where near the a/c. there are 2 identical connectors.
Old Jun 17, 2006 | 05:53 PM
das2123's Avatar
das2123
Those should be for the fogs. They should have a clip that makes them look like they won't reach, but you can take thst clip off.
Old Jun 17, 2006 | 06:05 PM
tjharder's Avatar
tjharder
tnks ill check that
Old Jun 18, 2006 | 01:06 PM
IGottaFreeNeon's Avatar
IGottaFreeNeon
Couldn't you just run new wires, it would probably save you a headache or two. I know thats what I would do if I was running into those problems. Just a thought.
