power window install help
Old Jun 20, 2006 | 09:50 PM
kmongru's Avatar
kmongru
Default power window install help
hi i have a 96 neon, and im looking to install power windows. I have a power window module for my alarm that would wind it up when armed. I have seen power window motors for sale, what else do I need? how do i go about doin this?? any help/input/criticism is much appreciated . thanks in advance
Old Jun 21, 2006 | 12:19 AM
spudsterier's Avatar
spudsterier
Default RE: power window install help
it all depends if the wires are all there alredy in the car, if not then you will need a whole wire harness inside the car, but otherwise you would need the door wiring, window tracks, switches, window motors, the brackets that hold the window to the glass, the door panels for power windows,(unless you can get the metal frame that hold the switch trim to the door and then just cut it out in your door) and that switch trim....that should be it....im getting ready to do the swap myself within the next few days, but i have averything needed from my other car, and i need to finish tinting the windows before i can put it all in
Old Jun 21, 2006 | 12:43 AM
kmongru's Avatar
kmongru
theres nothing in the car. I was trying to do this sort of an aftermarket way. Hoping that i could somehow wire in a motor, the switch and location are not an issue.
Old Jun 21, 2006 | 01:53 AM
das2123's Avatar
das2123
Easy way would be to go to a junkyard and pull all that you need.
