crane 14 cams ???
I was wondering what all i would need to install crane #180-0014 cams in my 98 dohc and around how much horsepower i would have after the install and guesses on 1/4 mile time after the install.
I have mopar ecu , aem intake, larger throttle body and dual exhaust.
You don't mean the Neon Magnum (SOHC) springs, right? Won't provide enough lift for even stock cams on a DOHC...
How much weight in the car? A typical stock DOHC should run mid-high 15's. Bigger cams, and larger TB as your only performance mods might drop you to low 15's. The AEM HAI and "dual" exhaust are probably hurting more than helping.
Best of luck!
Best of luck!
radar might be talking about the locaton of the filter, although its better then the stock intake, it still sits behind the engine and sucks in some hot air still, the CAI I recently bought is better then the stock one I had so im happy with that till I can make a custom one like spud did, now that's a CAI right there.
