Difference from Sohc to Dohc
Are you wanting to convert a SOHC to a DOHC or pull the SOHC out and put in a DOHC?
Pull a SOHC completely out and put a DOHC in is a direct bolt in - probably should change your PCM
If you are converting your SOHC to a DOHC - you will have to change out your pistons - after that it is a direct bolt on to the block with a DOHC head.
Overal - better performance in my opinion with a DOHC, but better Gas efficiency with a SOHC.
Did this answer your question?
