Electrical?
Old Jul 5, 2006 | 11:42 PM
Crog's Avatar
Crog
Default Electrical?
I'm having this peculiar problem, bought this car second hand, looks great.
It runs but keeps quitting after a few minutes. While its running, if i turn headlights on or hit the horn or release the park brake, the engine stalls out. Checked voltage at battery, 12.8 v when not running, 18 volts when running, changed PCM and same thing. Anyone have any ideas as to what can cause this?
Old Jul 5, 2006 | 11:48 PM
das2123's Avatar
das2123
Default RE: Electrical?
Sounds you have a bad ground or loose wire somewhere. Good luck.
Old Jul 6, 2006 | 02:17 AM
pimpberetta's Avatar
pimpberetta
18 volts sounds very high. Maybe voltage regulator?
Old Jul 6, 2006 | 03:47 AM
dogdaysunrise's Avatar
dogdaysunrise
holy crap... 18 volts? That will cook your pcm in no time.
