HEADS
Old Jul 8, 2006 | 01:36 AM
Dodge_Neon_R/T999's Avatar
Dodge_Neon_R/T999
Default HEADS
What is the cfm flow of the 2.0L head??? PLZ
Old Jul 8, 2006 | 04:40 PM
RadarLove's Avatar
RadarLove
Default RE: HEADS
There's a DOHC and 2 different SOHC's (possibly 3). No one can give you the "cfm flow" because you need other pieces of information as well, such as valve lift and applied vacuum (I'm assuming you're talking about flowbench numbers). On top of that, there's variance between identical heads. The flow of someone else's head shouldn't matter nearly as much as yours.
I don't even have a rough estimate for you, my head is stock and has only been off to change the head gasket.
Best of luck!
