'99 R/T Head questions
Old Jul 10, 2006 | 06:54 PM
J_sin26's Avatar
J_sin26
Default '99 R/T Head questions
Hey guys I was wondering if anyone had any tip for taking off the head. I was told I have to take the starter off. Am I headed in the right direction.
Old Jul 11, 2006 | 02:32 PM
dogdaysunrise's Avatar
dogdaysunrise
Default RE: '99 R/T Head questions
get your self a haynes or chiltons book. It will make your life alot easier. Good step by steps on taking that kind of stuff apart.
Old Jul 11, 2006 | 03:03 PM
das2123's Avatar
das2123
REMOVAL
(1) Perform fuel system pressure release procedure before attempting any repairs.
(2) Disconnect negative battery cable. Drain cooling system.
(3) Remove air cleaner inlet duct and air cleaner (Fig. 32), disconnect all vacuum lines, electrical wir-ing
and fuel lines from throttle body.
(4) Remove throttle linkage.
(5) Remove accessory drive belts.
(6) Remove power brake vacuum hose from intake manifold.
(7) Raise vehicle and remove exhaust pipe from manifold.
(8) Remove power steering pump assembly and set aside.
(9) Disconnect coil pack wiring connector and remove coil pack and bracket from engine.
(10) Remove cylinder head cover.
(11) Remove cam sensor and fuel injectors wiring connectors.
(12) Remove intake manifold (SOHC ONLY)
(13) Remove timing belt and camshaft sprocket.
(14) Remove rocker arm shaft assemblies.
(15) Remove cylinder head bolts.
FSM's ROCK!!!!!
Old Jul 11, 2006 | 09:47 PM
NYG's Avatar
NYG
The Starter is bolted to the Block - not the head
das2123 pretty much gave you the details - but I don't get the SOHC only on the intake manifold - both SOHC and DOHC you will can disconnect the intake manifold or leave it on the Head and remove it with the Head.
Old Jul 17, 2006 | 01:57 AM
J_sin26's Avatar
J_sin26
Wow thanks guy that is just what I needed. Thank you thank you thank you!
