Map sensor
Old Jul 18, 2006 | 02:49 PM
rpernack's Avatar
rpernack
Default Map sensor
I just got my car back and now i am getting code 14 for the low voltage for the map sensor. what couyld the problem be, and how would i correct it?
and is it hard to replace it if i have to?
Old Jul 18, 2006 | 04:38 PM
FuzzRacer's Avatar
FuzzRacer
Default RE: Map sensor
It could mean that the Map sensor is about to go and its giving you the heads up before it does, if that is the issue then you can just replace the map sensor, but on the models 96 and on the Map sensor and the IAT sensor are intergrated, so the price for the combinded sensor might be a little more expensive hope that was helpfull and good luck !!
Old Jul 18, 2006 | 07:58 PM
spudsterier's Avatar
spudsterier
it is very easy....jacking up the car might be harder
