95 Neon Problems
Old Jul 24, 2006 | 05:42 PM
Gryphin's Avatar
Gryphin
Default 95 Neon Problems
Ok, this is the situation, my car was running fine one day and that night it stop working when I was replacing the Ill. lights in the dash. It turns over but just wont fire. Some times its sounds like its about to start but sputters out and just turns over. Im thinking somthing with the fuel. The engine light is on and a mechanic said it was give a code about the fuel pump relay, which i replaced and nothing changed, he said it could be that or a short some where. The thing is like it didnt start for a day then the next day it fired right up. When i went to get the relay and i pulled the old one to take in to get a replacement and put it back in it didnt start. Anyone have any clue on what to do next?
P.S. When i got auto zone to hook it up for error messages, i dont remeber what it said exactly but it was like Manufactors Emissions control somthing. I tried the enine light check i got a 55 at the end and it blink like 3 then 3 then 5 then 4 then 2 then 5 then 5. I dont know what that two was in there for?
Old Jul 24, 2006 | 06:19 PM
das2123's Avatar
das2123
Default RE: 95 Neon Problems
Did you replace the relay or the fuse? Read the codes again because you read them wrong.
Old Jul 24, 2006 | 06:33 PM
FuzzRacer's Avatar
FuzzRacer
hm, yes pull the codes again If im understanding what you said correctly then I get: 13?, 35? 42? I got 13 from the phrase: and it BLINKED like 3 but im probably just totally wrong, pull the codes again and let us know please.
