can someone explain.......
Old Jul 25, 2006 | 07:36 AM
LilRedNeon97's Avatar
LilRedNeon97
Default can someone explain.......
can anyone explain this cleaning of the engine in crude lamens term? i dont get it. But i wanna do it.
Things you'll need....
1. a good high- pressure car wash.
2. A big bottle of "Formula 2001" by Turtle wax.
3. Some rags.
This trick is very easy and inexpensive, and the results are amazing. Our Neon has almost 98,000 miles on it and under the hood looks like less than 20k.
Okay take your car to the car wash and use the engine cleaner under your hood. Let it soak for a bit and then rinse it off. When your ready, Soak everything under your hood with 2001. If you have excessive dirt and oil grime under the hood, wipe it clean FIRST. After soaking everything with 2001, you should have a nasty white milky substance on everything. DO NOT WIPE IT OFF. Close your hood and start your car. Let your car run for 15-30 minutes, or until your car's temp gauge reads normal temp for 15 minutes.
Okay, now pop your hood again and drool, because it will look just like it did on the showroom floor. Maybe even Better.
before:
after:
it says take your car to the car wash and use the "engine cleaner" under your hood...... um, what??
Old Jul 25, 2006 | 12:08 PM
spudsterier's Avatar
spudsterier
Default RE: can someone explain.......
at the car wash there is a setting for engine cleaner.....just spray it all over the motor...then rinse....
spray the 2001 cleaner on the engine.....let the motor fun for a while...and there you go
Old Jul 25, 2006 | 12:33 PM
das2123's Avatar
das2123
You can let the car run while you wash the outside.
Old Jul 25, 2006 | 09:36 PM
LilRedNeon97
ORIGINAL: spudsterier
what kind of a car wash are we talking about here? im confused.... the car washes here are like a drive thru.
Unless its talking about the $2 car wash that some of the gas stations have.... is that what they mean? the do-it-yourselfers??
Old Jul 25, 2006 | 11:42 PM
spudsterier
yeah the do it yourself ones
Old Jul 26, 2006 | 12:20 AM
NEONRT98's Avatar
NEONRT98
Personally, I think you can do a better job with a do-it-yourselfer than what you get for 8 - 12 bucks for an automatic, less cost too!!
Old Jul 26, 2006 | 02:43 AM
LilRedNeon97
AH HAAA!!
Old Jul 26, 2006 | 06:41 PM
LilRedNeon97
i have that stock cover thing forgot what its called, leave it there??
Old Jul 26, 2006 | 07:39 PM
spudsterier
ummmmm. stock cover thing????...if its what i think ti is then yes..if you want
Old Jul 26, 2006 | 09:43 PM
NEONRT98's Avatar
NEONRT98
If your talking about the snorkel, YES LEAVE IT ON! If you take it off, your going to soak your air filter!!
