wheel studs
Old Jul 29, 2006 | 01:19 PM
frsuki's Avatar
frsuki
Default wheel studs
Hi! Im looking into rally racing my 97 dodge neon . I would like to know if they have the extended wheel studs for 95 to 99 neon front and rear . And where can I buy some ?
Old Jul 30, 2006 | 03:41 AM
RadarLove's Avatar
RadarLove
Default RE: wheel studs
Mopar used to sell them, part number P4452162. You can usually find them on Jegs or Summit for $35 or so for a set of 5. 1" longer than stock.
You might consider upgrading your hubs to ACR spec hubs/bearings, which are beefier and will last longer. Mopar used to sell those as well, part number P5007314, $75-100 each depending on where you go. They do have do be pressed in though...
Best of luck!
