sucked up some water
Old Aug 5, 2006 | 11:01 PM
got magnum's Avatar
got magnum
Default sucked up some water
what happends when you suck up water and then you a have a sound like to tin cans beating together under your hood please help
Old Aug 5, 2006 | 11:33 PM
spudsterier's Avatar
spudsterier
Default RE: sucked up some water
you get a new motor
Old Aug 6, 2006 | 12:41 AM
FuzzRacer's Avatar
FuzzRacer
how exactly did you manage to suck in so much water for the car to do that? was the CAI filter ran close to the ground with no ran bag over it or bypass or something else?
Old Aug 6, 2006 | 01:21 AM
das2123's Avatar
das2123
It's called hydrolock and your rods are probably broke into peices. Water can't compress, so something else goes boom!!!!
Old Aug 6, 2006 | 05:43 PM
ScrapYurImport's Avatar
ScrapYurImport
dude your screwed that really sucks man.[:@]
Old Aug 7, 2006 | 06:36 PM
tooslow's Avatar
tooslow
take of your spark plugs and then crank the car if it is really hydrolocked the water should shoot out. fyi if asoon as you relized you hydrolocked you should have tried this some pll have gotten lucky and avoided replacing a motor that way
